Sharp ARC270 calibration
  • Dean
    • Feb 2007
    • 19
    I am getting very pale copies and having problems running the calibration.
    I have tried loading 11x17 in all three cassettes but when I press execute the machine runs for a few seconds then it says load 11x17. I can run 11x17 copies and prints but the calibration and service mode 46-24 will not run. What should I check.
    Dean
  • tmaged
    Owner/Service Manager
    • 1866
    Try the end user calibration. If that doesn't work check out this tech tip on SharpNet. ARC270-12913
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • NCArt
      Mountain Tech
      • May 2008
      • 81
      Have tried cleaning the printhead LED's? I ran into this today doing a calibration on a AR-BC260. If you re read the message, does it say "calibrated failed, patch cannot be printed, Use 11"x 17" paper" ? If it does, your printheads are dirty. Also clean the optics real good as well.
      • tmaged
        • 1866
        Art, the C270 uses laser units unlike the C260. The C260 was based off the Oki C9200 series which are LED printers.
        Hope that helps !
        -Tony
        www.dtios.com
          • 22996
          Calibrating this machine is not for someone faint-of-heart. It requires special color patches, and test patterns. I'll attach the procedure.
          Keep in mind that you need to do all the steps, in the order designated in the bulletin, or it will come out worse than when you started.
          Ok, so my bulletin file is corrupt. The one you're looking for is:
          AR-C150-005R
          • NCArt
            Mountain Tech
            • May 2008
            • 81
            Oops, my bad....never worked on a C270
            • tmaged
              • 1866
              Me either, I downloaded the manual.
              Hope that helps !
              -Tony
              www.dtios.com
