AR-507
  • T911
    • Jun 2007
    • 628
    AR-507
    can i reinstall a print system back on to this 507 after disabling it in service mode and removing it from the machine. if so, procedure appreciated. thanks t
    • 23009
    All you should need to do is enable the scuzzy (SCSI) port A or B, whichever you are using, in simulation 26. Sorry, I don't remember the sub-code to sim 26. =^..^=
    • T911
      • Jun 2007
      • 628
      thanks blackkat, it's 22-44, but A is set to 1 for printer and what do i set B to. Thanks t
        • 23009
        Set the one you are not using (B) to "0" =no connection.
