can i reinstall a print system back on to this 507 after disabling it in service mode and removing it from the machine. if so, procedure appreciated. thanks t
AR-507
All you should need to do is enable the scuzzy (SCSI) port A or B, whichever you are using, in simulation 26. Sorry, I don't remember the sub-code to sim 26. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Set the one you are not using (B) to "0" =no connection.If you'd like a serious answer to your request:
