MX-C301w Noisy Fuser drive
  • Jammed
    • Jun 2015
    • 33
    [Misc] MX-C301w Noisy Fuser drive
    MX-301w noisy fuser drive
    I was curious if anyone has pin pointed the cause of the rattling noise from the fuser drive cluster. Before I go ordering all kinds of clutches and gears, i was hoping someone already pin pointed the cause. It sounds like a pack of tic tacks being shacked. lol. I've lubed all gears and bushings and rollers. Run the test for FUM, sounds horrible. We are reconditioning 6 of these boxes, some only have 50k on them. 3 out of 6 have this rattle noise from fuser drive. WTH?
    Has anyone been there done that?
    TIA
    -Steve
  • RascalMJ
    • Mar 2009
    • 174
    Re: MX-C301w Noisy Fuser drive
    TIA
    -Steve
    Pretty common issue, not sure of all the models, but you may wanna search this site for all the threads on this type of fuser/similiar and all the bulletins over the years.
    I haven't had many on newer units, but I remember 311's and some others being a pain with all the bulletins, codes, and fractured parts.
    • mttech
      • Mar 2014
      • 127
      Most of our noise issues are caused by the upper heat roller bearings. May want to try swapping some fusers around.
      • jp74msj55
        • Oct 2014
        • 146
        TIA
        -Steve
        I have had 2 of these recently. Delivery drive unit which also drives fuser. Not fun. About 2 2 1/2 hour job and I recommend you bring
        to your office since a pain and try to stay organized. Here is your part # dunt-8748uszz.
        You can take fuser out and hold onto it in Sim 6 fuser load test and still hear noise to elimanate fuser assy. Good luck and take your time.
