sharp 450 2nd tray adjust
  • jpcopy
    • Apr 2006
    • 256
    we have a 450 that second tray won't adjust thru service mode. any idea befor we truck 50 miles. machine reads sensors from 04-11. it a renal so we might just have to swap out and bring back to shop but some outside thinking might help.
    • 23010
    To adjust the multipurpose tray width go to simulation 40-12 and follow the prompts.
    If you cannot get a valid adjustment check the bank of size switches inside the rear frame. It's pretty common to get paper jammed back there.
    • jpcopy
      • Apr 2006
      • 256
      when to customers office after trying to get them to set 40-12 over the phone and we could not set either. no paper or dust in sensors if no one else has a suggestion guess we just have to swap her out
      Thanks for the responce
      • jpcopy
        • Apr 2006
        • 256
        problem solved someone must have been playing in the tray setting. that's all it took fill stupid but when you don't know your machine inside and out it will happen
