M950 misfeeds from all trays
  • a soda can
    • Jun 2025
    [Jamming] M950 misfeeds from all trays
  • Bgorby
    • Jan 2018
    • 7
    Re: M950 misfeeds from all trays
    I would replace all the feed clutches around 2meg and that one has 4.5M.
    • ivan123
      • Oct 2014
      • 54
      For my opinion best solution is to disable jam detection and you will find which problem is mechanical or electrical.
      I dont remember exact sim number
      Also update firmware.
      We have couple m1204 which is over 25milion, no big problems until now
      • jamie@ricohids.co.nz
        • Jan 2018
        • 3
        What happens when you do a input output test on effected parts?
        • ivan123
          • Oct 2014
          • 54
          If you asked me
          Machine will disable sensors, so if paper pass through machine sensor/detection is problem,
          If stil he had a jams, there is some mechanical problem (clutch, gears, paper path...)
          • mansart
            • 852
            SIM 7-1 MISFEED DISABLE
