MX-M356N scanner error
  • Dewald
    • Feb 2015
    • 15
    Hi I have a 356N sharp printer that make blue area when scanning to PC. Only happens when using document feeder and not from glass. I have replaced document feeder and copy lamp etc. but it still appears. Hope some one can assist. Please find attached pic.
  • driving lots of miles
    • Jun 2016
    • 397
    Re: MX-M356N scanner error
    have you replaced the slit glass? there has to be a reflection or line on it somewhere.
    • Dewald
      • Feb 2015
      • 15
      Hi Thanks for advice but when i replaced the doc feeder i did replace that thin glass strip. Any other tips i ccan try???
      • ZOOTECH
        Senior member of CRS
        • 3375
        The slit glass of the doc feeder is for the duplex (second side) scan. The slit glass next to the original glass is for the first side scan.
        • Russtech
          • Apr 2017
          • 8
          You may want to check the white reference plate and make sure it isn't dirty or marked up. Also I usually like to run SIM 44-6 or 44-26 and have the machine recalibrate it's grayscales
            • 22999
            My guess is that your enduser has been copying books off of the glass, and has been pressing down hard enough with the DF to warp the glass downward. As light source #1 passes the edge of the copyboard glass it snags, and bends the reflector. Now that reflector blocks the light path to the yellow and magenta CCD receptors.
            I know that it should affect both the DF original feeds AND the scans off the glass, but sometimes these things surprise me.
            From the database:
            Toshiba eS4555C: Copies and scans have a cyan band toward the center of the page in the feed direction. Yellow and/or magenta are absent because the reflector for light source #1 is bent. When the enduser copies a book they press hard enough to warp the glass, then it catches on the reflector. Reform the reflector for light source #1.
              • 22999
              Something like this?:
