full color print only making jam problem in fuser unit.
  • Service@PRT
    • Oct 2016
    • 181
    sorry for the last post i made..
    good day!
    i have one mx2301n always getting paper jam when printing in full color like scanned passport or photo's, but when in black and some color with text it does not going jam.. i adjusted finger on fuser and make density lighter. still same problem checked fuser temp all good. heater roller and rest of the unit looks good.
    no available same unit near that area.
    hoping for your input on this one.
    thanks
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • spanky
    • Sep 2012
    • 468
    Re: full color print only making jam problem in fuser unit.
    Increase the void area on the lead edge of the copy/print
      • 23002
      It would help to know the jam code, and the machine model number, but in general yes: if you're getting accordian jams in the fuser claws you may have too small a lead edge or trail edge void. On text documents typically 3mm is enough, but with heavy (photographic) fill 4.5 to 5mm lead edge void may be required. =^..^=
      • Service@PRT
        • Oct 2016
        • 181
        No jam code.. just automatically paper jam on fusing unit either 1/2 or 1/4 of a4 paper being fused and then jam. Mx-2301n is the model of the machine.
        Sent from my HUAWEI VNS-L21 using Tapatalk
        • Service@PRT
          • Oct 2016
          • 181
          Will try that one.
          • JR2ALTA
            • Feb 2010
            • 2033
            Perhaps on your color drums have a flipped cleaning blade. This would allow you to make BW copies but jam on color with ppd2_drum code
            • mansart
              • 852
              Possibility......
              Gear on rear of Primary Transfer cracked. Additional load of the color transfer rollers pressed to color drums enough to cause gear to slip.
              But "no jam code"????
              • Service@PRT
                • Oct 2016
                • 181
                Originally posted by mansart
                Possibility......
                Yep no jam code because i told to the client that if jams occurs, dont let the machine run or rest it for a while after removing the paper, just to make sure not to reach h5-01 for error code.
                • spanky
                  • Sep 2012
                  • 468
                  Did you run a sim 23-2 to print out jam codes?
                  If no jam code you probably have an innerlock switch that is breaking contact for an instant
                  • copiertec
                    • Jan 2016
                    • 2197
                    Along with lead edge void adjustment and using photo mode and using thick paper setting, you could try using thicker paper, which in turn has less curl when exposed to heat of the fuser rollers.
                    • joe_vanacker
                      • Dec 2016
                      • 28
                      good day!
                      thanks
                      Hi,
                      does it jam before it gets in the fuser? if so i would check the gear on the belt unit NGERH1668FCZ1
                      regards
                      • Jack79
                        • Jul 2014
                        • 312
                        Are you using generic toners? As someone mentioned use thicker paper first (120 160 gsm)
                        • Service@PRT
                          • Oct 2016
                          • 181
                          Originally posted by joe_vanacker
                          Hi,
                          regards
                          Its in the middle of the fuser. Some toners already fused in the middle them jammed.
                          • Service@PRT
                            • Oct 2016
                            • 181
                            Original one. I might try the thickness also. Will be back there next week to try all the mentioned solutions. Thank you
                            • joe_vanacker
                              • Dec 2016
                              • 28
                              There is a mod for the rollers just above the fuser unit. Check if the gap between the rollers is not to big. Otherwise install the modification
                              Verzonden vanaf mijn iPhone met Tapatalk
