Sharp AR-337 PPD2_ST1 Jams out the gazoo
  • xeroid
    Document Technologies Pro
    • 148
    I have replaced both registration rollers, along with the PPD2 sensor, shimmed the rt cover latches. Only shows 100K on it as a donated machine to a cash strapped non-profit that I would really like to help out.
    Any Ideas
  • mrfixit
    Senior Technician
    • Sep 2007
    • 83
    Clean the clutch pack on the rear frame.
      • 23006
      I've got a few possibilities for you:
      Misfeeds (jam code PSD_N, PPD2_ST1, PPD2_ST2, PPD2_NT2) leaving two pages doubled up just before the registration roller. Paper skews at the registration roller on AR-287. The lift spring for lower pre-registration guide rear moves forward inhibiting the movement of the pre-registration guide. Re-position the lift spring to the lower pre-registration guide rear all the way to the rear frame.
      Misfeeds (jam code PPD2_NT1, PPD2_ST1, DUP) Z-folds 2nd side of duplex at the registration roller, or overlaps two pages at the registration roller. Duplex only on AR-287, AR-336. Defective duplex clutches. Replace duplex clutches (PCLC-0290FCZZ, PCLC-0291FCZZ).
