Sharp MX-FXX1
  • Tech2002
    • Aug 2008
    • 334
    Sharp MX-FXX1
    This is probably an easy one - have a MX-FXX1. Outgoing Faxes okay - Incoming Faxes - Fax Unit Rings but will not connect to Receive. Any suggestions?
    Thanks.
    • 22994
    Could the reception mode be set to "Manual" or "Ans Mach" instead of "Auto"?
    Also check to see if distinctive ring has been enabled. =^..^=
    • Tech2002
      • Aug 2008
      • 334
      Thought of this - Client sent me an email with little or no info. I was doing a pre-emptive - that's probably it. I wanted to see if there was anything I might have missed. Thanks for your reply BlackCat4866.
      • NCArt
        Mountain Tech
        • May 2008
        • 81
        Recheck and reseat your FAX ROM. If that doesn't fix it, reseat the DIMM in slot 4. My tech rep had me replace the DIMM in slot 4 because of several units with the same issue. I hope this helps.
        • Tech2002
          • Aug 2008
          • 334
          This make sense to try. I had an MX-2700N with a LCD Screen issue. I thought it was the screen itself it wasn't showing well. I pulled and re-seated the memory chip and that ended up being the fix.
          Your input is appreciated. Thank you.
