Sharp mxm350 light copies
  • soutec
    • 13
    I HAVE A NEW INSTALL SHARP MXM350. WHEN INSTALLED I RAN SIM 25-2 AND EVERYTHING APPEARED
    NORMAL. 2500 COPIES LATER COPIES WERE SO LIGHT
    YOU COULD BARELY READ TEXT. I CHECK THE TONER
    CARTRIDGE AND IT APPEARED TO BE LOCKED UP, SO
    I REPLACED THE DEVELOPER AND RAN 25-2 AGAIN
    ONLY THIS TIME IT CAME UP WITH EE-EU CODE TWICE
    AND THE THIRD TIME IT RAN THE SIM NORMALLY. I SWAPPED OUT THE OLD TONER CARTRIDGE WITH A
    NEW ONE AND LEFT. I CHECKED BACK A WEEK LATER
    (6500 COPIES) AND THE COPIES WERE NICE AND DARK
    SO I THOUGHT I HAD FIXED THE PROBLEM. ONE MORE
    WEEK AND THE PROBLEM IS BACK COPIES SO LIGHT YOU CAN'T READ. I REPLACED THE DEVELOPER
    ASSEMBLY THINKING THE TONER SENSOR MUST BE
    BAD. WHEN RUNNING SIM 25-2 IT KEEPS GIVING THE
    ERROR "EE-EU". IS THIS A BAD MAIN BOARD OR WHAT? I WOULD APPRECIATED ANY HELP?
    THANKS
    PERRY
  • tmaged
    Owner/Service Manager
    • 1888
    EE-EU is the code for under toned. If you've switched DV units, it sounds like the main PWB isn't getting the signal right. If you're stirring a new bag of developer, it has the right amount of toner in it already, so you're not concerned about the the cartridge, toner motor or anything that related to adding toner to the DV. Are you positive the DV unit is turning? That or maybe the wiring harness would be the only other thing.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • soutec
      • 13
      Tony,
      Thanks for responding. The Developer must be turning
      on because it makes great copies immediately after
      adding new mix. As for the harness are you talking about
      the harness at the back of the machine than runs from the
      developer plug connection to the PCM board?
      Thanks for helping.
      Perry
        • 23009
        EE-EU is an undertone condition. You can get this for a variety of reasons. Let's start with the obvious ones that you've already covered:
        dead developer, locked up toner cartridge, developer not stirred.
        The not-so-obvious possibilities: loss of agitation to the developing unit (damaged drive couplers, rounded out 'D' bore in the developer drive gear), right type of developer, defective toner sensor, seizing developing cylinder, and dead last PCU PWB.
        Now I realize that most of these problems are symptomatic of a much more used machine, but that doesn't make any of them impossible. =^..^=
        • tmaged
          • 1888
          Yep, that's the only connection between the Toner sensor on the DV unit (which you've replaced) and the main PWB. It'd pretty much have to be one of those 2 things. The harness is the cheapest unless the machine is still under warranty.
          Hope that helps !
          -Tony
          www.dtios.com
          • soutec
            • 13
            Tony,
            Yes the machine is still under warranty. I'll the check the developer wiring harness then as a last resort replace the
            pcm board.
            Thanks for the help.
            Perry
            • tmaged
              • 1888
              In the original post you replaced the Developer Assembly. Is this the entire DV unit?
              Hope that helps !
              -Tony
              www.dtios.com
              • soutec
                • 13
                Tony,
                Yes the complete developer assembly and new mix
                as well. I tried SIM 25-2 probably 5 times and kept
                getting the "EE-EU" code. By the way I meant to say
                the PCU PWB earlier.
                Perry
                  • 23009
                  Maybe I'm crazy, but I think we're making this thing too complicated. I would check to make sure that the developer is agitating (everything rotating that should).
                  The wiring harness couldn't be more than a foot long from the developer connector to the PCU. I can't imagine this being very difficult to pin out.
                  • tmaged
                    • 1888
                    You've eliminated everything but the board & the connection to the board. I would think the board would be more likely the culprit. In my experience though, Sharp has had the fewest "bad boards" of anything I've worked on.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    • soutec
                      • 13
                      Well I guess I just took for granted everything was
                      agitating ok since the copies were ok for the first
                      2500 copies or so. I just filled out a part order form
                      for SHARP for the DV harness and the PCU PWB.
                      Now I'm starting to second guess myself. Blackcat
                      are you suggesting a developer drive problem instead?
                      I sure would like to cover all the bases.
                      Thanks All
                      Perry
                      • Tech2002
                        • Aug 2008
                        • 334
                        What about Firmware Updates?
                          • 23009
                          Are you still working on this problem? I'm sorry I didn't see you post.
                          • Tech2002
                            • Aug 2008
                            • 334
                            I was just perusing the pages myself and thought that this might be a fix. There was two-pgs on this. Whenever I call the Sharp Help Desk this is usually what they ask me.
                            By the way, Merry Christmas to you and your family.
