Sharp AR-407 Jamming @ registration roller
  • aoe
    • 41
    I have a Sharp AR-407 in my territory that buckles and jams @ the PS roller. Cleaned the registration sensor with no luck any ideas would greatly be appreciative. Thanks
    Bruno,
  • pjdbm
    • Sep 2007
    • 360
    Replace the clutch pack in the back, some people clean them but I had never any luck with that NONSENSE.
    • xeroxsharp
      • Nov 2008
      • 270
      It is much easy to replace transport drive assy with all clutches
      • petrus
        • 155
        I also faced this kind of problem,I ve try change the feed clutch (transport) assemblly ( all of the clutch,if not wrong 4 clutches)changed the registration clutch & roller.its work only for a few copies.I have three of this machine.so now I let the machine just take a long rest in the dark room.
        these machine already runs about 1m,400k and 600k.
        If any tech have better solution are really appriciated.
        • aoe
          • 41
          Thanks guys, I am going to price out a clutch pack and hopefully my customer will go for it. thanks for the quick response.
          Bruno,
          • xeroxsharp
            • Nov 2008
            • 270
            I replaced more than five transports (drive assy with gears and clutches),and never had any problems for long time. Costs in EU are about 150 EUR ,and it is better to replace drive assy than you replace only clutches.So this is my advice. Good luck.
            • petrus
              • 155
              of cause I changed the drive assemblly and it still the same,
                • 23009
                What jam codes? =^..^=
                • xeroxsharp
                  • Nov 2008
                  • 270
                  If you have not (Z fold jam),means that resist roller is OK,tray to change this small peaces,once I took very long time to solve this problem (actuator was not in original condition).
                  AR505 PG 21 Vertical transport unit
                  MLEVP0758FCZZ AE C Vertical transport actuator
                  PSHEP4626FCZZ AE C Pressure PG sheet
                  CPWBF1256FC31 AT E PFD PWB
                  Sorry if I am wrong!
                  • petrus
                    • 155
                    me also so sory .actually mine problem is the image have vertical white line.from top to bottom-A4 sideway.I suspected the pre regist roller push the paper toward the regist roller and make a too big buckle between the pre and regist roller.initialy the problem is Z folded paper.after changed the transport clutch assemblly then this problem came.I means vertical line.
                    • xeroxsharp
                      • Nov 2008
                      • 270
                      Is there any diferences if you make some changes in SIM 51-2 ?
                      • pjdbm
                        • Sep 2007
                        • 360
                        To the point:
                        Sharp had issues with to much grease on these, by changing just one, you will be back for the others.
                        The right thing is to replace all five clutches at once, this cost about $75.00 plus a shit load of time to do it.
                        Or you can buy the whole unit for $120.00 and get it done within a hours time.
                        I made my decision years ago on this.
                        • jprecht
                          • Dec 2008
                          • 104
                          sharp-407 jamming@registration roller
                          I will assume that you have verified that the rollers are turning and your clutch is energizing the roller drive . if so you can go into simulation and change the timing of that clutch.
                          IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
                          THAN TO SPEAK AND REMOVE ALL DOUBT
