Ar 507-scaner is not moving everytime,and it make noise
  • xeroxsharp
    • Nov 2008
    • 270
    Hello,could enybody tell me about your experiance with problems around scaner-if you try to make a copy from document glass,sometimes the scaner makes some noise and it not move all the way. Is there any adjastments or I need to replace scaner motor. I allredy lubrycate the scaner raills but not fix this problem. Any sugestions? Thanks!
  • MHeon71
    • Oct 2008
    • 489
    Haven't worked on it in a while, but I use to replace the scanner motor and PWB that the motor plugs into.
    • xeroxsharp
      • Nov 2008
      • 270
      Thanks,have a good day.
        • 23007
        Yes that's a common fault on the Cougar series of machines. Just make sure you get the right combination of parts:
        Early production machines had a 2 phase scanner motor (large brass flywheel on the scanner motor). Later machines use a 3 phase motor (no flywheel).
        I have used scrap 2 phase motors & driver boards with no problem, as long as it's a match with the machine you have. The upgrade to 3 phase motors was not done on many of the machines in the field. The motor and driver board are unique, and there is a simulation setting that must be changed to accommodate the change in phase. I can look it up if you need this information. There is a post in here (somewhere) detailing the simulation. =^..^=
        • xeroxsharp
          • Nov 2008
          • 270
          Blackcat, thanks for very detail information about Cougar.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1884
            26-59 changes the Phase for different motors. Just changed a motor/pwb combo yesterday.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • xeroxsharp
              • Nov 2008
              • 270
              Tmaged,thanks to you too,I am still waiting answer from my customre.
