MX-7040 transfer cleaning blade flipping
  • Hansen88
    • 1050
    This machine when new had the transfer blade flipping problem. We put the mods on it as per the service bullitens and the machine has been trouble free. Belt and blade have been changed at maint intervals and all has been fine. Now all of a sudden it is flipping blades again. We have put new blades on, replaced belt and blade,tried every kind of patting powder and we can not get this to stop. I know this is a problem with this model. Anybody figured what the actual cause for this to happen?We have others of this model out that have never had this problem. Thanks for any help or advice on this.P.S this is the main primary transfer clean blade
  • OlliK1969
    • Nov 2016
    • 310
    Re: MX-7040 transfer cleaning blade flipping
    Have you done this?
    Technical Report CCE-1874 TRANSFER ROLLER PRESSURE SPRING
    CAUTION FOR ATTACHMENT OF 2ND TRANSFER ROLLER PRESSURE SPRING
    19.03.2018
    • Hansen88
      • 1050
      Originally posted by OlliK1969
      Have you done this?
      19.03.2018
      I did not look at that specificaly but I just looked at the bulliten. I should have mentioned in my post this is the primary transfer cleaning blade that is giving me problems.
      • kdr363
        • Apr 2019
        • 63
        Does the customer run at least 10% color volume compared to black? There's a soft switch for another model that may apply to periodically apply yellow toner to the belt to keep the blade "lubricated".
        • Hansen88
          • 1050
          They do run low volume color. I looked and did not find anything about the soft switch to periodally apply yellow toner. Do hou happen to have any more info about that even for othe models? Thanks
            • 22973
            Is it OEM toner? I had a machine (not Sharp) that scoured the transfer belt in 30K because of "Premium Compatable" brand toner (and yes they could not even spell "Compatible" correctly. =^..^=
            • dsmith46
              • Oct 2016
              • 81
              Take a look at bulletin TT-102016_1. It states which soft switches to set to add yellow toner in the 5050 through 6070 series machines. I'm not sure if the settings will be the same for the 7040, but I wouldn't doubt it.
              Good luck!
              • Hansen88
                • 1050
                Well my company uses crap Royal imaging toner,but luckily they do not have generic for this model. Stuff runs like trash in all the other models but hey, it saves money,so they say.
                • Hansen88
                  • 1050
                  Good luck!
                  Thanks for the info. I will look into that.
