Paper Registration buckle adj ?
  • xring1958
    • 166
    I havent needed this adjustment for some time so of course I cant remember what Sharp Calls it.
    Im getting skews when copying from ADF or Original glass. Have replaced feed rollers cleaned transport rollers and adjusted values in 50-10
    I think I just need to increase pressure of paper at the registration roller and increase what I have always called paper buckle.
    Or if you have another possibility I am missing clue me in.
    I checked the manual but am not finding it. I anyone remembers this adj. I would appreciate it. I will continue looking
    • 23007
    Re: Paper Registration buckle adj ?
    It might help to know what model you're working on. =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      On many models (color and mono) the rear spring pressure breaks the plastic on the registration unit. I have fastened a zip-tie around the plastic and then hooked the spring to that.
      • tsbservice
        Field tech
        • 8010
        Paper buckle, loop or aligning amount is good starting point for that sort of problems.
        I'm not by any means familiar with Sharp models but few things comes to mind.
        Do you have skew from all paper sources?
        Can you print not copy, if so do the printouts also are skewed?
        • tsbservice
          Field tech
          • 8010
          😆, I remember old analog Toshiba 1550, they were subscribed to that.
          I had a large paperclip and small torch in my toolbox to drill hole in plastic lever and hook the spring.
          • xring1958
            • 166
            It is a MX-M453 not all but many and probably most sharp products use same adjustments codes
            Yes All Paper trays but didn't test bypass
            Thanks again
            • mttech
              • Mar 2014
              • 127
              I agree with JR2ALTA on this as I have seen it a couple of times. It doesn't take much to remove the registration unit to check this out. If it is not broken check page 5-79 in your service manual. I think that is the sim you are looking for.
                • 23007
                Isn't that a DragonII?
                I had a DragonI that the customer used such poor quality paper that the registration paper dust collector was packed solid in a relatively short period of time. It would hardly turn there was so much paper dust. =^..^=
                • Hansen88
                  • 1066
                  I also agree with JR2ALTA that the registration roller rear pressure spring attatchment point broke off. I have also seen this on this model a few times. Take a strip if paper about 1 or 2 inches wide and roll it into the registration rollers at the front end and then pull the paper out. Now roll it into the rollers at the rear end and pull the paper. There will probably be no pressure or very little compared to the front.
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Are you getting skewed prints/self prints as well?
                    • xring1958
                      • 166
                      [QUOTE=ZOOTECH;773106]Are you getting skewed prints/self prints as well?
                      They don't print much on the machine they prefer their desktop printers but they copy and scan a lot ( Title Company)
                      when I print the total sheets I can see some skewing. They are over an hour away so I will go back when the part comes in.
