Sharp ARC260 F2-41 Error
  • Ricefoxnz
    • Jul 2008
    • 30
    Heyas
    Having an issue with a Sharp ARC260, keep getting the error code F2-41, which is a problem with a cyan tank, we have replaced every tank and every drum unit, and of course reset the trouble codes.
    Anyone had any issue like this before?
    Thanks!
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Loose Connector from TES harness (ARC260M/P Part Guide section 23, item 4 DHA1-3365FCZZ) (ARBC260/320 Part Guide section 22, item 4, DHA1-3365FC11) to TES sensor (ARC260 Part Guide section23, item 15, ARBC260/320 Part Guide section 22, item 15, VHPGP1A71L3-1)
    This problem has been reported for Yellow, but could also occur on the other TES sensors.
    sigpic
      • 23008
      Just to clarify:
      Are you working on a Bear: AR-C260
      or a Whale: AR-C260M
      Huge difference!
