Sharp FO-5700 not feeding legal
  • ebm
    • Apr 2007
    • 183
    I have a Sharp FO-5700 that does not recognize legal paper. When legal is received or copied, it prints on two sheets of letter from the cassette. If it is forced from the tray it prints on two sheets of legal. I have replaced the sensor in the tray that indicates legal positioning. I have tried option settings, memory clear, and soft switches.
    • 22999
    Sorry, no manuals where I am at. The paper size in the tray is programmed, but I don't remember exactly where. If I had I machine I could browse to it. Sorry I'm not much more help... =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1872
      See if this helps.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • ebm
        • Apr 2007
        • 183
        I've tried replacing the internal tray sensor and I also get 5 vdc switching 0v-5v when I slide the guide in and out of the legal position. I will try to check this again. Thank you.
          • 22999
          Thanks for reminding me tmaged. These are really junky switches. They're used in several places on Sharp facsimile. I've gotten new ones that have worked worse than the original. =^..^=
