Finisher FN6
  • swagreis
    • Jun 2008
    • 92
    Finisher FN6
    when using sorting or stable sorting in offset tray of fn6 which atttached in AR-M450
    the paper comes in the finisher and pass till the last step which the paper or sorted papers which stabled together wil come out from finisher
    it jammed in finisher and still in it till u pull it out
    sometimes i noticed a skew in paper position in the place it jammed
    anyone can advise
    thanks
    • 23009
    The jams that I have come across are usually POD1S, MPPD3_S, MPPD4_S, MPPD5_S, with the paper skewing throughout the finisher or mailbox.
    Remove the pass-through portion of the finisher and examine the rearmost fins for paper cuts that delay and/or skew the paper. I can usually file or sand down these fins to remove the cut portions. It works fine with smaller fins, just not cut fins. While you're in there examine the gate to make sure it is not broken or cut. Also remove any noise damping foam from that solenoid.
    That should get you started. =^..^=
    • CopierTechofOmens
      Agitating Artificer
      • 268
      I've also run into the frame on the top of the finisher being slightly pushed down causing jamming/skewing. FN6 has been discontinued and is harder to get parts for...
      sigpic
        • 23009
        So the only finisher option on the MX-M450 is a FN7 or its most recent reincarnation? =^..^=
        • CopierTechofOmens
          Agitating Artificer
          • 268
          As far as I know. Tried getting parts, and all our suppliers/dealers say it's discontinued. Only the parts that cross with the MS6 mail-bin stacker are available
          sigpic
            • 23009
            There certainly were a lot of problems with the F1-87 codes. It took us a while to figure it out, but when solved they run pretty good. =^..^=
