Sharp ar-m455n h4-01
  • J_Lee
    • 111
    Tried 2 BRAND NEW oem fusers and checked lamps on both. Reset with simulation works fine until machine gets turned off and gets cold again when you turn it back on it pops the code again. I reset fuser temps to default also. Any help?
    Thanks J.
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Use DIAG (SIM5-2) to check the heater lamp
    Blinking operation.
    If the heater lamp blinks normally:
    Check the thermistor and its harness.
    Check the thermistor input circuit in the
    control PWB.
    If the heater lamp does not light:
    Check for heater lamp disconnection and
    thermostat disconnection.
    Check the interlock switch.
    Check the AC PWB and the lamp control
    circuit in the control PWB.
    Use DIAG (SIM14) to cancel the trouble.
    But you already knew that from reading the manual
    sigpic
    • J_Lee
      • 111
      I dont post on this site unless I have read the manual. Ended up being wrong fuser sent to us by our parts distributor. Though identical they use different voltages.
        • 23010
        We need more members like you.
        Thanks for posting the results. =^..^=
