Sharp mxm 266n
  • davebtech
    • Apr 2015
    • 170
    Sharp mxm 266n
    Paper curling coming out of exit, seems to happen a lot with this model,any input ? Fuser temp adjustment maybe? Fuser looks good.any input thanks Dave
  • driving lots of miles
    • Jun 2016
    • 397
    Re: Sharp mxm 266n
    Here in the middle of the country we have had a lot of issues with high moisture content. open a new ream of paper and see if it still curls.
    • Hansen88
      • 1053
      Re: Sharp mxm 266n
      I see there is a service bullitin about putting a mylar on the side of the exit foam rollers. It does not say what exactly it is supposed to fix.
      • davebtech
        • Apr 2015
        • 170
        Re: Sharp mxm 266n
        [QUOTE=driving lots of miles;1091535]
        • davebtech
          • Apr 2015
          • 170
          Re: Sharp mxm 266n
          Hey thanks just posted on this while you were posting.do you have part #s for Mylar and possible copy of bulletin? Thanks Dave
          • Hansen88
            • 1053
            Re: Sharp mxm 266n
            Here is the bulliten
            • davebtech
              • Apr 2015
              • 170
              Re: Sharp mxm 266n
              Many thanks! Going to give it a try,I could see summer being a tough road with this issue.......
              • yurisan
                • Dec 2007
                • 113
                Re: Sharp mxm 266n
                We have two of these machines that we just got in (low meters of approx. 10K) that are both doing this. The original delivery sponges are crap. The foam degrades & softens and they fail to deflect and decurl the paper exiting the delivery unit. I found that the delivery sponges used in the Orion series (MX-M364N to MX-M565N) are far superior. The inner ones are of a very dense foam rubber that holds up well. Luckily, I save everything and have a few sets from machines that got inner finishers where you have to remove them before you install the guide that delivers the paper to the finisher. Installed these in the MX-M266N's and Voila' the problem is solved. The stiffer foam sponges are installed in the inner positions.
                • davebtech
                  • Apr 2015
                  • 170
                  Re: Sharp mxm 266n
                  • yurisan
                    • Dec 2007
                    • 113
                    Re: Sharp mxm 266n
                    The inner, stiffer foam rubber sponges are PSPO-0013FCZZ and the outer, softer foam sponges are PSPO-0005FCZZ. They are also much cheaper than these delivery sponges mentioned in the bulletin. When disassembling the delivery unit on the MX-M266N, be careful to not knock the sensors out of their position in the plastic frame - easy to do. As a rule, I do a minimal re-assembly for test purposes. If satisfied, I then complete the re-assembly, including putting back any plastic panels that I have removed. It's one of those "Murphy's Law" things.
