SF 2314 - CH -
  • vaclav borc
    • Jan 2008
    • 75
    SF 2314 - CH -
    display indicates CH , after power on.
    what should I do. thanks
  • mik84
    CH means, that the TD cardridge is not installed. Check if TD unit is in place. Here is multi-language user manual: Detail Information : SF-2314/2414/2514 Operation-Manual PL RU HU CZ GB DE FR DK
      • 23009
      You'll also get CH if the door is open.
      Don't waste your time on this one. Too old. It wasn't a good machine even when it was new. =^..^=
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1888
        How soon they forget. This model cut power as soon as the front door interlock was compromised.
        And we always had pretty good luck with them. The 16/18/20 of that era was the real turd.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • efe311
          • Oct 2008
          • 114
          IF THE MESSAGE CH IS FLASHING THAT MEAN THE TD UNIT IS NOT assembly CORRECT BUT IF THE CH MESSAGE IS FIXED THAT MEAN THE MANUAL DOOR IS OPEN OR NOT CLOSED GOOD (THE MANUAL DOOR OPEN WITH TWO GREEN LEVER IN THE LOWER OF THE TOP HALF) OPEN THEM & CLOSE AGAIN
          • vaclav borc
            • Jan 2008
            • 75
            Originally posted by efe311
            if the message ch is flashing that mean the td unit is not assembly correct but if the ch message is fixed that mean the manual door is open or not closed good (the manual door open with two green lever in the lower of the top half) open them & close again
            i solved problem: Was wrohg stabilizator 7805 on cpu el. Board
