DSPF 2 to 2 lead edge is way off side 1 only
  • bigdaddyooo
    • Dec 2014
    • 212
    Have an mxm365 with the DSPF. On single-sided copies through the feeder registration is dead on. When doing 2 to 2 copying, side 1 is way off. There is a huge trail edge void. Side 2 is dead on. Dspf has just been rebuilt and cleaned. Any ideas? It was disassembled and blown out so no paper clips or staples.20200401_093236.jpg20200401_093937.jpg
    Are you the police? "No ma'am, were musicians"
    • 23009
    Re: DSPF 2 to 2 lead edge is way off side 1 only
    Does it have a simulation 50-6? If it were me I think I'd take a little peek in the manual. Who knows? There might be something useful there. =^..^=
    • bigdaddyooo
      • Dec 2014
      • 212
      Of course it does and I have "peeked" in it. Ty Mr. Helper for the suggestion. Now it is intermittent.
        • 23009
        So, side #2 remains registered properly while side #1 intermittently does not register properly?
        Sorry I don't have any ideas about that. =^..^=
        • bigdaddyooo
          • Dec 2014
          • 212
          Yes sir, that's correct. Very strange. Side 2 is ALWAYS dead on. Now side 1 is intermittent whereas earlier it was everytime. Clutch maybe?
            • 23009
            This is a single pass document feeder. The original is being scanned simultaneously on both sides at the same time. So how can the front of the page be late, while the back of that same page is on time? The original would have to be in two places at the same time. I don't have any kind of explanation for that. =^..^=
            • bigdaddyooo
              • Dec 2014
              • 212
              Thank you, EXACTLY my thought. I did not do multiple copies so i do not know if it was a copier registration issue. Doing 3 each time now to see if all 3 are side 1 reg off
                • 23009
                Now COPY and PRINT registration is done one side at a time, so yes, you can have a clutch affecting PRINT image registration. =^..^=
                • dsmith46
                  • Oct 2016
                  • 81
                  Just do a Sim 50-28 for the SPF. This should take care of it. If it doesn't, I would be looking at a CID.
                  • mttech
                    • Mar 2014
                    • 127
                    You can make a 2 to 2 using the glass to help see if it is a DSPF or engine problem.
                    • bigdaddyooo
                      • Dec 2014
                      • 212
                      A 50-28 was the 1st thing I did. If you read the entire thread..1-1 is dead and on 2-2, 1st side reg is way off BUT side 2 is always dead on.
                      Why on earth would I look at the CIS? Side 1 is done via the scan lamp unit on the slit glass
                      • bigdaddyooo
                        • Dec 2014
                        • 212
                        So true BUT you know how that goes. Since I posted, the machine strangely works just as it should. Side 1 is now dead on and I can NOT make it do what it was before. When doing 2-2 copying I am making 3 copies but like I said, it will not do what it first was. FRUSTRATING
                        • Copi
                          • Aug 2019
                          • 11
                          I believe that these feeders have had problems with staples falling down into them and causing strange registration problems. I think they have added some mylar shields to alleviate this problem. You can remove some covers and remove the feeder and shake out the debris but it sounds like it has already (fixed) itself just from opening and closing the feeder.
                          • bigdaddyooo
                            • Dec 2014
                            • 212
                            Again if you read the entire post, I put that that was done before I even started this thread. Smh
                            • repn1999
                              • May 2010
                              • 310
                              so this only happens on side 1. can you reproduce the same random position issue by scanning from platten glass, since side 1 is read from ccd. if so then that would rule out dspf mechanical and settings and leave you with scanner drive and such. i have seen one or 2 old dragon machines with the lamp unit sticking randomly causing weird issues and fixed it by clearing the sire scanner rails and the little wheels on the scanner unit that ride on the rails and then lubing with turbine oil. i have also seen a paperclip or staple on the dspf control board cause strange issues. might also want to check wall voltage and power to the scanner motor. I have seen scanners on small machines like arm257 and mxm314 do something similar along with making a strange whining noise when scanning. when i checked voltage to the motor 24v showed only 19v. changing the dc power supply fixed it. since i dont know what machine this is on its hard to give a better answer.
