sharp mx-365n phantom ADF misfeed
+ More Options
Posts
  • sharpfail
    • Jun 2020
    • 5
    We've got a sharp mx-365n that reports a misfeed in the document feeder that can't be cleared. It instructs us to lift the lid and check the panel underneath the ADF. All paper has been removed, I've opened the panels and blown it out with compressed air and cleaned the rollers. Nothing I do makes a difference. It just keeps showing the instructions to clear the misfeed.
    I understand there's a possibility that a sensor may be knocked out of place or just dirty. But I don't know where the sensors are located and I don't have a service manual for this machine.
    Any help is much appreciated.
  • bilyahn
    • Dec 2006
    • 1470
    Re: sharp mx-365n phantom ADF misfeed
    I have had this happen with the SPPD5 sensor. It will stick and not return to it's home position, if you close the DSPF forcefully sometimes it will reset but that doesn't fix the underlying problem. It is located directly under the paper feed tray in the DSPF. I would print out sim 23-2 to see which sensor to be sure. It will require quite a bit of disassembly to fix.
    Good luck.
    Bil
    • Hansen88
      • 1056
      • sharpfail
        • Jun 2020
        • 5
        Thank you both very much for your help. After running sim 23-2 it looks like the SPOD sensor is the main issue.
        mx365 sim 23-2.pdf
