Sharp mx-m453 will not print after scanning from document glass or ADF
  • bisiawoeyo
    • Dec 2007
    • 65
    Sharp mx-m453 will not print after scanning from document glass or ADF. It will only show 'original being read' after every attempt to make photocopy and the ready light comes again. Please what be the cause and any likely solution? Thanx in advance!
    Bisi Awoeyo
  • copiertec
    • Jan 2016
    • 2211
    Re: Sharp mx-m453 will not print after scanning from document glass or ADF
    What have you done so far in an an attempt to fix the issue?
    • JLSam
      • Jun 2015
      • 605
      What kind of document? Does your machine have DSK? Is a check? Does the document have a security foil to prevent copies? Or does the document contain the EURION constellation?
      EURion constellation - Wikipedia
      I think you are copying something you are not supposed to. :|
      But... we need more information.
      • fireater
        Repair God? not quite
        • Apr 2006
        • 253
        Bisi Awoeyo
        is job build enabled?
        I fix copiers ...Well Sorta
