MX-3100N adu gate soliniod location?
  • copiertec
    • Jan 2016
    • 2211
    I'm having an issue on an MX-3100N when the paper duplexes it jams in the fuser area with a dogear as it tries to go into adu gate on 8x11 but will not jam on 8x11R. So far I have replaced these items to try to resolve the issue 1) new fuser kit 2) new exit assembly 3) replaced the right side door still have exact jamming issue, I believe it could be the gate solenoid but can't seem to locate where it is. I really hate to ask but am sick of looking at the parts manual and not locating it. Any help would be greatly appreciated. I know the client needs to be in a newer copier as well, sales is working on it.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: MX-3100N adu gate soliniod location?
    This is a common problem *if* you have a bridge unit. The gate solenoid lever breaks. Accessed by removing the bridge front cover, easy enough. PN 0CW4145P00401
    • kdr363
      • Apr 2019
      • 63
      I'm pretty sure the adu gate doesn't have a solenoid, only gravity once the trail edge passes and paper is reversed. The key will be to figure out where the dog ear is occurring. Probably from the fuser. It doesn't handle LTR full page color very well. Adding fuser oil to the fuser rollers will help for a short time, but running LTR R works better.
      • copiertec
        • Jan 2016
        • 2211
        Thank you, I believe you are correct. What I am going to try to do is swap out the fuser with an account down the road. I installed a rebuild kit, but did not replace the entire fuser unit.
        • copiertec
          • Jan 2016
          • 2211
          thank you, JR2ALTA, you are correct, except this unit does not have a finisher attached and no bridge unit, I appreciate the input.
          • ZOOTECH
            Senior member of CRS
            • 3375
            Does it have the right side exit tray? If so, the solenoid wires (for the exit tray) may not be routed correctly so the gate fully opens and closes.
            • copiertec
              • Jan 2016
              • 2211
              Thank you, Zootech, I thought the same thing as the original door does have the right side exit tray and I swapped it out with a right side door without one, but it still jams on duplex only because of a dog ear. I thought maybe after installing a new exit unit it would resolve the issue but it still dog ears. New exit unit, new fuser kit, different right door. I am going to swap fusers with a know working one to see if the dog earing still persists. I also am thinking maybe there is not enough pressure on the fuser pick because of a stretched spring possibly ( they visually looked good).
              • ZOOTECH
                • 3375
                When you switched right side drawer without the rt side exit tray, did you reset 26-1?
                • copiertec
                  • Jan 2016
                  • 2211
                  Yes.
                  • copiertec
                    • Jan 2016
                    • 2211
                    Went back out last week to the client to "try something," I put an extra wrap on springs for the upper and lower fuser picks, turned the paper back to 8.5 X 11 and it seems to have resolved the issue of jamming on duplex.
