Sharp AR M355N
  • tcypy1961
    • 773
    [CQ] Sharp AR M355N
    After replacing developer; dev seal, drum and blade copies improved yet leaving lines/streaks. Don't see anything to indicate coming from drum. Possible charge grid???
    Sending 3 samples streaks on 2 of the 3. The before copy and something I copied so that lines/streaks could be seen. Best I can tell copier was doing this before my service. Customer has not been using this copier for several years. There are 2 other copiers being used mainly for printing; customer feels the need to have this copier available for copies; says they are getting busy. Glad somebody is.
    Thanks!!!IMG_0468 GC Adv Ins.JPGIMG_0470 GC Adv Ins.JPGIMG_0471 GC Adv Ins.JPG
    • 22996
    Re: Sharp AR M355N
    Did you clean the paper dust collector on the registration assembly? If it's been dumping toner, there will be a lot in the paper dust collector. It may diminish if the current developer isn't dumping. =^..^=
    • JLSam
      • Jun 2015
      • 605
      Re: Sharp AR M355N
      $5.00 says you didn't replace the sub blade, despite being a routine maintenance item. [emoji3577]
      Replace the sub blade bro, toner is leaking.
      Good luck!
      Sent from my GM1917 using Tapatalk
      • OEM1
        • Mar 2015
        • 33
        Re: Sharp AR M355N
        First, Always clean the charge grid & sawtooth. Second, Your problem looks like the teflon is coming off the upper fuser roller.
        • kirkeb
          • Dec 2012
          • 31
          Re: Sharp AR M355N
          agree with OEM1 Fuser roller
          • JLSam
            • Jun 2015
            • 605
            Re: Sharp AR M355N
            I agree that it's what it looks like, but I'm confident it's the subblade. Any competent tech would of seen the fuser ghosting due to the Teflon being worn.
            It's the sub blade bro. [emoji3577]
