Sharp AR-M355N
  • tcypy1961
    • 773
    [Error Code] Sharp AR-M355N
    Copier has a C4-30 code which I know is the controller can motor. I'm fairly certain it's on the front side however this Copier has a AR FN-6 finisher. I received instructions on it's removal. Does it have to be removed to get to the fan motor in question??? If not how is it accessed???
    Thanks!!!
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp AR-M355N
    Yes, in order to take the top off of the copier body the finisher needs to come off. 3 screws in the front, 2 brackets in the back and it plugs into the desk unit so 4 screws there, then lift carefully to remove
    Good luck
    Bil
      • 23003
      Re: Sharp AR-M355N
      Other than being awkward it's no big deal. The finisher is not heavy, but it's in the way. =^..^=
