developer come out
  • sjinachandran
    • Jun 2025
    developer come out
    Hi Tech Guys,
    Basically i am a Toshiba tech. I have installed e-161
    (same as sharp AR 160). I have faced the problum of
    developer spillage while copying (in 4 machines same
    problum). I tried the sulution of changing the new
    drum kit. but the problum was not solved. Pl help me to
    solve the problum.
    The suggetion is greately appreciated and thank in
    advance.
    s.jinachandran
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Is the mylar over the mag. roller flipped underneath?
    sigpic
    • Slave4It
      DV coming out could be due to mylar on mag roller, also could be due to machine not being level or mag roller surface contamination. Have seen the level problem many times, try using a bullseye level on the glass to detemrine. Good luck.
      • sjinachandran
        Tku for your replys friends. i will try it
        • RSCA
          • Jul 2008
          • 112
          If the main charge electrode and grid have toner on them it can also cause developer pull. I make a point the remove the grid in order to clean both.
