ARM451 ~ CE-00
  • spotlifter
    • Mar 2008
    • 65
    ARM451 ~ CE-00
    Hello, handsome guys . I need to know what sim to turn off this error without removing the network card. For purpose of offline. I know how to turn off the ARM300/350/450 (sim66-80) but somehow the 451/455 settings is different. Thanks.
    sigpic
  • Jaws
    • Oct 2007
    • 235
    It is under customs settings, under key operator
    • spotlifter
      • Mar 2008
      • 65
      aww....how stupid i am...
      sigpic
      • ZOOTECH
        Senior member of CRS
        • 3375
        Try TC 66-1, soft switch 103, and turn bit 8 on.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1868
          You guys do WAY too much work. Just uncheck TCP/IP in the Key op settings.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
            • 22999
            Right-O, tmaged.
            • ZOOTECH
              • 3375
              "You guys do WAY too much work. Just uncheck TCP/IP in the Key op settings."
              You are kidding, right? Four keystrokes difference and through TC, I don't have to power down to enable new network settings.
              • tmaged
                • Oct 2008
                • 1868
                The actual key strokes aren't that much work. Just figuring out what & where the soft switches takes more time.
                There's always more than one way to do something. Getting it done is the most important.
                Hope that helps !
                -Tony
                www.dtios.com
                • ZOOTECH
                  • 3375
                  Agreed; and I appreciate a new way (disabling TCP/IP) to help a customer over the phone.
                  • CopierTechofOmens
                    Agitating Artificer
                    • 268
                    Ok so how many newton/meters of force will I be saving? Exactly. Perhaps we should arrange a controlled experiment.
                    sigpic
