Sharp ARM 207 Network-ARNB3 error E7-11
  • xeroxsharp
    • Nov 2008
    • 270
    Hello guys
    Have a problem when use COLOUR network scaning (from glass or RSPF). If I take another dpi resolution is allmost every time the same resoult. Copying,printing and scaning-only black or grayscale works without problems. Allredy replaced drum,developer,cleaned mirrors,lens and white reference and still not good on colour scaning. Please,need some help!
    Copier has 65K in 3 years
    ARNB3 is without extra addicionaly 256MB ram
    SIM 63-1 (42)
    SIM 63-7 (102)
  • DavePo
    • Jul 2008
    • 305
    Sounds like the ccd unit is ever so slightly out of adjustment. Try turning the screw to adjust the front elevation a eighth of a turn one way or another. Check to see if improves or worse. If worse go opposite. Have seen this on a couple of these models, only ours would error scanning period. Adjusted ccd and took care of issue.
    • CopierTechofOmens
      Agitating Artificer
      • 268
      ARM160, ARM165, ARM205, ARM207E7-11
      1) Throughly clean the scan lamp reflectors and replace the lamp if neccessary.
      2) Upgrade firmware to latest version.
      sigpic
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1887
        Omens is right. The newer firmware version increased the error detection time of the E7-11 error for that machine.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • TechGeek
          • 158
          I had the same problem. Sharp had a tech tip that said to replace the CCD unit. After i changed the CCD unit everything worked good.
          • xeroxsharp
            • Nov 2008
            • 270
            Is the part number the same like arm 160,because I do not have PG for arm 207? Thanks again.
            • TechGeek
              • 158
              The CCD lens unit part number is CLNS-0006RS52
              • oeshuron
                • May 2008
                • 259
                We had the same problem with one. The firmware upgrade did the trick.
                • TechGeek
                  • 158
                  oeshuron is right about the firmware update. I had to replace the CCD unit even after trying the firmware update.
                  "this is the description of the firmware update from Sharp:
                  The new ROM Versions are listed below. MCU Version: 2.05 (No Change) IMC Version: 3.00 (No Change) PNL Version 12.00 (No Change) Fax Version 2.14 (Changed) For FAX (From June 2007) In 2007, the United States has changed the dates of its daylight saving time observance. Engine (From December 2006) The operating margin for occurrence of E7-11 error (Shading trouble /White correction) has been increased. Since the E7-11 error may occur due to fogging of the reflector, the E7-11 error detecting level has been decreased."
                  good luck
                  • xeroxsharp
                    • Nov 2008
                    • 270
                    Thanks guys,I think that I have enought informations to fix this issue.
                    • xeroxsharp
                      • Nov 2008
                      • 270
                      After I replaced scan lamp,colour scaning is working OK. Hope it will work for few time.
