MX8081
  • bigdaddyooo
    • Dec 2014
    • 212
    MX8081
    I have a MX8081 that came in with just black and yellow imaging. I reseated all the pcu connectors after unplugging machine and now I get all but no actual image. Here is the 64-5 before and after the reseating of the PCU pwb
    Are you the police? "No ma'am, were musicians"
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 715
    How many copies, age of machine, have you done anything else to troubleshoot?
    • bigdaddyooo
      • Dec 2014
      • 212
      Tried 44-2 & 50-22 both errored. See pics About 90k on machine
      • tedtech
        • Dec 2011
        • 50
        did you check for a dv pull? Easy to check
        • bigdaddyooo
          • Dec 2014
          • 212
          IMG_7997.jpgNO dv pull but no toner in yellow.
          TSG_K Toner sensor control voltage input value (K) 1v
          TSG_C Toner sensor control voltage input value (C) 1v
          TSG_M Toner sensor control voltage input value (M) 12v
          TSG_Y Toner sensor control voltage input value (Y) 1v
          TCS K-Y all around 120-130
          Going to change the MC pwb
          • nanohitmen
            • Apr 2019
            • 117
            Edit: this machine sucks, co-coworker had to do Full PM and replace the LSU and the registration resist unit as well for the same issue yours is showing. Updated to reflect what he did to the machine. he had the same issue.
            • bigdaddyooo
              • Dec 2014
              • 212
              update.
              Nothing we tried repaired the machine. Sent it back to the distributor. Problem solved.
              • AndresM
                • Jan 2016
                • 37
                Laser units are the culprit when something like this happens.
                • Imprestik
                  • Aug 2012
                  • 297
                  You can clearly see the laser unit is toast. Look at all the missing lines in the black boxes on the 64-5 on the 2nd image. That alone says it's time to replace the laser unit
