MX7090 MX8090 H3-01 & H3-02 Errors
  • gmoore081
    • Jun 2018
    • 14
    [Error Code] MX7090 MX8090 H3-01 & H3-02 Errors
    Good Moring Sharp Forum
    I'm putting this post out there to see if anyone else is experiencing this issue
    We have about 6-7 of these devices out there regularly doing H3-01 & H3-02 - some from brand new out of the box
    So far we have done the following
    H3-01 - replaced both non contact & contact thermistors to the pressure roller & pressure roller lamp
    H3-02 - replaced the 2 non contact thermistors & contact thermistor to the belt & the belt lamps
    Also on some of these fuser units the connectors have been cleaned
    Also tried a different refurbished fuser unit & on anther a new fuser unit
    We can see in SIM44-14 that the thermistors are reading too high a temperature. While in this SIM & with the side door open some of the thermistor readings are stuck on the same temperature & don't cool down as expected
    Our next step is to order a PCU board & see what this does
    Any information from this forum would be appreciated, if you've experienced this issue too
    Thanks in advance
    Graham
  • OlliK1969
    • Nov 2016
    • 311
    Re: MX7090 MX8090 H3-01 & H3-02 Errors
    Hi
    there was a tech bulletin for Griffin2/Phoenix2 from March 2020
    There is a cleaning tool for the pins of the fuser unit and the pins inside the maschine.
    Sound like the same think
    Huby-340 is this cleaning tool
    • gmoore081
      • Jun 2018
      • 14
      Originally posted by OlliK1969
      Hi
      Hi Olli
      Thanks for your post, however I have tried this already
      Regards
      Graham
      • Chr15tophe
        • Dec 2011
        • 42
        Thanks in advance
        Graham
        Did you get to the bottom of this ?
        thanks
        • Imprestik
          • Aug 2012
          • 297
          Would also like to know if there is a resolution for this as we are in counting the same problem.
          1 device is brand new out of the box and we are experiencing this.
          Any help would be appreciated
          • gmoore081
            • Jun 2018
            • 14
            This makes me feel slightly better that its not just us suffering from this
            We did have someone from Sharp Technical attend a device that was regularly throwing up these error codes. They said it was probably down to a clone file (which we know it wasn't)
            We just now deal with it internally. Replace the thermistor in question that the fault relates to & it settles down for a while
            So, no we haven't found the fix for this, but I tried pretty much everything in the fault finding process
            It is however better that it was
