MX-3051 Blue line
  • smithson.brown
    • Oct 2012
    • 5
    MX-3051 Blue line
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 693
    Approximate page count? Attach an example if possible! Does the line move or does the width change at all? LSU is a possibility, same with PTC(doubt it, but easy to clean), also what about the discharge lamp grid within the unit? Did you perhaps try to swap cyan with another drum unit to see if the problem moves? That would rule out the entire process unit. If there were potential power issues, I would think it's possible that the one of the power supply boards could be failing, and either way, could have caused another component to fail.
    • Yuri Terence
      • May 2024
      • 3
      Hi. You may want to check the mc electrode components. From my experience with these Phoenix2 Griffin2 machines It usually is the cyan and black springs which are heavily corroded.
      You can replace them or clean them with sandpaper and alcohol. Here is the part no. for your refence MSPRC4559FCZZ.
      Sorry for the mistakes. I'm new here but I have been a lurker for the longest time. This forum has saved me a lot of times. Time for me to give something back to the community.
      Hope this helps!
      • Hart
        • Feb 2024
        • 399
        Simply swap the whole drum unit from cyan to yellow for example and see if the problems move.
        Secondary transfer roller ?
        Is there any toner or DV spilling in the copier ?
        • smithson.brown
          • Oct 2012
          • 5
            • 23007
            Where is that quality sample?
            • Hart
              • Feb 2024
              • 399
              Did you replace the transfer belt only or the whole unit ? Did you clean the roller under the belt ?
              • smithson.brown
                • Oct 2012
                • 5
                We replaced the entire unit.
                Also, I will post an example of the blue line tomorrow when I get into the office.
                • ihatefinishers13
                  • Feb 2020
                  • 693
                  Hope this helps!
                  Weird, we were told that from a DSS of Florida(through the hotline) to do that, and our DSS called and said don't bother because it's only going to happen near saltwater, which we are not.
                  • Yuri Terence
                    • May 2024
                    • 3
                    They told us to replace the high voltage pwb but we don't have a spare machine to take it from.
                    So we went through the swapping of drums and applying conductive grease on the springs from the inside(which worked for a week).
                    It was a tear down job so that was our last option but was worth it after all.
                    FYI the machines have almost 2m clicks and yes I do live in the carribean.
                    • tedtech
                      • Dec 2011
                      • 50
                      Have you put a line monitor on to see if something odd is going on at the customer's site? We currently have one in the shop doing the exact same thing with blue lines, but we can't get it to do the lines at the shop. They show up early and often at the customer. We tried power boards, LSU, PTC, drums, all that stuff and nothing worked. I'd look closer at the power situation
                      • Mittle Lix
                        • May 2024
                        • 5
                        Hope this helps!
                        Have had 3x Machines with intermittent Cyan lines where nothing seemed to fix them, These springs were exactly our problems. Corrosion on the springs. Replacing whole MC Electrode Unit with changeover parts we had fixed our problem each time.
                        • Hansen88
                          • 1066
                          Hard to say without seeing what the line looks like, but it could also be scan optics need cleaning.
                          • Imprestik
                            • Aug 2012
                            • 297
                            This is a extremely common problem on the CR4 and CR4.5 series now.
                            100% it is your mc electrode unit.
                            The spring corrode overtime and cause this issue in the main scan direction.
                            Please see attached bulletin for part numbers.
                            It's a little fiddly job, not very hard
