MX-M5050 Error 20 / 21 Meandering adjustment
Hi. I'm not familiar with error 21 but I've seen error 10 that eventually turned into error 20. From my experience it has something to do with the pressure release mechanism. A bearing was not seated properly onto the frame at the front side of the fuser unit which can also break the actuator.Comment
Also, check your meandering adjustments from factory, we keep getting receiving BP machines with the adjustment out of spec and a few have blown up within the first 100k.👍 1Comment
There is no handy/tech guide for North America. They mention multiple adjustments for the main unit in the install guide, but not once mentioning meandering adjustment. We end up having to adjust 25-50% of them out of the box.Comment
The meandering procedure has changed.
You are supposed to do meandering adjustment with a cold fuser.
Once you rebuild a fusing unit, install it and leave the duplex door open, boot up the device and enter simulation
Once in simulation, sim 6 - 8, then close the duplex door and start the simulation
This is the only true way to do meandering adjustment👍 2Comment
