Snap Ring plier suggestion
  • JR2ALTA
    • Feb 2010
    • 2033
    Hola-
    I was handed down a nice plier for the fuser retaining rings but have since lost it. I bought some god-awful Harbor Freight unit with interchangeable tips but it always falls apart. Looking for a tried and true pair. I am afraid some of the nicer ones on Amazon may be too thick for the tiny circumference holes we need.
    TIA
  • Hart
    • Feb 2024
    • 408
    I use this low-cost one (it does the job perfectly) but if you want something nicer, Knipex is the go to brand no ?
    • JR2ALTA
      • Feb 2010
      • 2033
      I'll get those. With the Knipex, I was worried the little prongs would be bigger for like automotive snap rings. Not sure what of these sizes are standardized.
      • nanohitmen
        • Apr 2019
        • 115
        I got mine off the snap on truck, been reliable for the last 6 years and if the tips ever go bad you can exchange them at the truck.
        This gallery has 2 photos.
        • JR2ALTA
          • Feb 2010
          • 2033
          I always get a good feeling with Snap On tools. Maybe because of the calendar in my Uncle's garage growing up.
          • JLSam
            • Jun 2015
            • 605
            I got WORKPRO after my friend who works on cars sweared by them a while ago.
            https://www.amazon.com/WORKPRO-4-Pie...st_sto_dp&th=1
            I use them routinely, purchase date Aug 2019... so far so good.
            • Larhal
              • 571
              I have the Blue Point set from Snap On. 10 years now.
              Larhal
              If all else fails read the Service Manual!
              If that fails, meet me at the pub and we will discuss it.
                • 23008
                In the old days I was mostly rebuilding fusers on console devices, so larger clips (25 to 50mm), so the larger tool was required. More recently I've been working on KM, Kyocera & Lexmark, which has microscopic clips (3 to 8mm), requiring smaller tools and grinding down the inner surface so they close down to nothing. It depends on what you're working on.
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  Nice, well-worn set. Personally, I've only needed them on Sharp fusers.
                  • havokprod
                    • Oct 2012
                    • 159
                    I got these back in september so far so good. Price was reasonable
                    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                    • AndresM
                      • Jan 2016
                      • 36
                      I work on Lexmark machines and I never had a use for something like this only one Philips screwdriver and does it.
