MX-3570 Melted ADF rollers
  • nanohitmen
    • Apr 2019
    • 117
    Like the tittle says I went for a U5-20 code, found a staple on the adf board, then when I checked the adf rollers after it wouldn't feed found this. Just wondering if any one has ever seen this. Melted rubber wrapped around the grey roller as well, strangest thing Ive ever seen.
  • ntbann
    • Jan 2012
    • 628
    They are supposed to have a rubber outer sleave. I would suspect that someone tried to clean it with some kind of solvent that melted the outer sleave.
    • havokprod
      • Oct 2012
      • 159
      I have had this happen twice before to me, 2 diffrent machines and locations, I shruged and moved on with my life. But it is interesting
      • odinp
        • Jun 2019
        • 33
        This is a common issue for those resist rollers.
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 707
          Melting though? I've only ever had them ride off after being in there for quite a while. Definitely think a solvent was in play that shouldn't have been.
          • odinp
            • Jun 2019
            • 33
            yes, nearly every 3070 4070 etc we currently have in the field has had this happen., I've even had the top layer of that roller literally melt and end up leaving a trail of sticky gunk through the paper path.
            Im pretty sure its age related and not because of a solvent.
            • ihatefinishers13
              • Feb 2020
              • 707
              Are you near Chernobyl? Never had this happen in 10 years... What cleaning solutions are your techs using?
              • sharphead
                • Aug 2009
                • 285
                I can't remember when Sharp started using this roller, it might have appeared as a mod on the ARM700u. I've never seen one do this we clean them with isopropyl
                • lky1978
                  • Mar 2009
                  • 483
                  i saw some techs in SG using AR-DU4 feed roller to replace this sticky roller. So far so good
                  • Doug.P
                    • Aug 2015
                    • 55
                    We have seen something similar to this at a customer that was scanning and copying carbonless multi part forms and the chemicals form the carbonless paper was damaging the rollers almost as bad as what your picture shows.
                    • Imprestik
                      • Aug 2012
                      • 297
                      Just start using the CR5 reverse roller, their just as good if not better
                      • miller01123@gmail.com
                        • Jun 2019
                        • 55
                        Definitely age related.
                        • odinp
                          • Jun 2019
                          • 33
                          LOL, In Australia where its hot so that may have something to do with it.
                          The techs here use water or isopropyl alcohol.
                          • ihatefinishers13
                            • Feb 2020
                            • 707
                            Is there a kit with the CR5 roller in it? I've found that Sharp doesn't really give out kit numbers anymore.
                            • Doug.P
                              • Aug 2015
                              • 55
                              MX-753DF SPF Roller Kit has all 3 Pickup,Feed and Separation Rollers in it
