mx 3060N reset password
  • Ecostampa Monteverde
    • Oct 2024
    • 3
    Hello,
    I picked up a sharp Mx 3060 from a costumer fo us.
    I would like to use the copier in my office but i don't know the admin password
    I tried to follow the "Howto_Initialize_AdminPassword_and_ServicePasswor d_20151116" instructions but the machine isn't connect to internet and moreover i don't know which is the "liaison" mail
    Anybody can help me ?
    Andrea
  • Doug.P
    • Aug 2015
    • 55
    Default password is admin all lowercase. If it is not that you will have to go through the Sharp hot line Portal and go through the password reset process.
    • WackyJack
      • Feb 2021
      • 82
      You can try this if you can access another machine that hasn't had the admin password changed
        • Oct 2024
        • 3
        Hello Doug, have you the link to hot line portal ? I tried serveral website but i found only suppor sites
        thanks
          • Oct 2024
          • 3
          Hello, the copier isn't connected to ethernet; is it possible to restore backup through usb ? In this case have you a backup to use ?
          • Doug.P
            • Aug 2015
            • 55
            thanks
            This is the link that I use here in the US but you have to be Sharp Authorized. https://service.sharpamericas.com/Pa...?returnurl=%2f
            • Clone
              • Oct 2021
              • 19
              I can send you the file
              • boutn
                • Jun 2016
                • 547
                go into the sims, 56-2, import the file in this zip
                resets password to 'admin'
                • oscarconil
                  • Oct 2021
                  • 27
                  Hello,
                  I tried to follow the "Howto_Initialize_AdminPassword_and_ServicePas swor d_20151116" instructions but the machine isn't connect to internet and moreover i don't know which is the "liaison" mail
                  Andrea
                  From the machine, it cannot be accessed through the website.
                  Security settings: ini.private_data/machine.
                  The execution takes a long time, about half an hour
                  • Michko
                    • Sep 2010
                    • 32
                    do you have this file for 3061 etc and BP too ?
                    • ridgemill
                      • Sep 2017
                      • 190
                      The same file can be used for the 2651 etc.
                      BP is now different, after the recent PW policy change. We tried copying the storage backup from other copiers, however the PW still remains the same.
                      • ihatefinishers13
                        Senior MFP Technician
                        • Feb 2020
                        • 704
                        Don't copy anything besides the CSV files to BP machines!!!! You're just asking for trouble! MX series machines you would get away with minimal to no issues, but BP's you'll end up regretting it.
