BP-FU703 VS BP-FU701
  • boutn
    • Jun 2016
    • 540
    is there a difference between BP-FU703 VS BP-FU701
    according to the handy guide:
    BPFU703 should be for the BPxMx machines?
    BPFU701 should be for the BPxCx machines? But the fusing belt is also the BPFB703
    The price for the FU701 is much lower than for the FU703
    FB701 is discontinued
    i'm confused...
  • ridgemill
    • Sep 2017
    • 182
    BP-FB701 is discontinued, now replaced by BP-FB703.
    BP-FU701 (colour device only) is still available.
    BP-FU703 (mono device only), uses the same belt (BP-FB703).
    More than likely the fusers are the same, except for one pin position or extra sensor.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 665
      Would be really cool if they were just the same... Then again, it would be really cool if they weren't overengineered garbage, too.
      • Andypraeuner
        • Jun 2013
        • 33
        The only difference between the fusers from the B/W to the color is the exit from the fuser. On the B/W it is taller than on the color. I put a fuser from a color BP into a B/W BP and it worked just fine. However there is a gap between the top of the fuser and the delivery unit then and could eventually cause jamming issues. The fuser from the B/W will not fit into the opening of a color machine because of height of the fuser exit.
        • havokprod
          • Oct 2012
          • 159
          I don't think i have run in to any fuser unit where I say "yep they nailed it.... it's a good one"
          • ihatefinishers13
            • Feb 2020
            • 665
            It wouldn't be so bad if the whole unit wasn't so expensive compared to a rebuild.
            • jp74msj55
              • Oct 2014
              • 146
              Agreed, Ridiculous. Sharp has got you by the kahunas!!!!
