Print release MX5071
  • boutn
    • Jun 2016
    • 547
    We have a client where, when certain people log into the machine with their pin, some files are shown in the print release section.
    The files can not be deleted
    The files can not be printed
    The machine says 'document is in use' when trying to delete them.
    User has been made admin - no difference
    Delete stored data after specified time has been set to 1 day + reboot - NOK
    "Delete all" has been done on webpage - NOK
    Files can not be seen in document operations, but i'm not sure if they usually show up there?
    they can only be seen if the specific user signs in on the machine itself.
    Is there a way to delete these files without resetting the whole machine?
  • harps05
    Field Service Engineer
    • Mar 2012
    • 112
    This machine is connected to another for Tandem Print by chance?
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 707
      You could try 66-10, Image Memory Clear, and I will also suggest to BACKUP THE HARD DRIVE. It WILL fail. Not IF, it definitely fail and you'll have problems.
      • iHateSharpFusers
        • Jul 2024
        • 38
        How is the HDD? Print release taxes those Toshiba drives heavily. It gets replaced AT LEAST once in its ~5 year life if running print release.
        • boutn
          • Jun 2016
          • 547
          some more tests:
          delete user/remake user : files stay in print release
          change username: files stay in print release
          change pin: files are gone
          So the files are coupled to the pin of the user.
          This makes sense as the user authenticates with the pin on his pc.
          But how do i get rid of the bad files? (without having to change all the pins)
          • ihatefinishers13
            • Feb 2020
            • 707
            Originally posted by boutn
            some more tests:
            66-10?
