Sharp copier
  • Chunk_Blower
    • Mar 2018
    • 5
    Originally posted by iHateSharpFusers
    Reference JLSam's latest post. Clutches and paperclips on the DSPF PWB are most likely by far.
    I swapped the clutches around and having same issue...Should I bite the bullet and order a DSPF PWB? No paperclips, staples or debris on board.
    • iHateSharpFusers
      • Jul 2024
      • 38
      Do you have any spare clutches from a scrap machine laying around? I am assuming swapping you meant changing position within the same unit. Also, how is the error code and jam history? Other indications of debris on the DSPF is contant jamming because a sensor goes inop. I would remove the board and see if there is any debrtis under the board indicating it once was on it then slid off after users lifted the ADF a few times. I have had times where some issues go away after removing debris but some issues continue.
      • RColon-Fraser
        • Jan 2021
        • 5
        I'm having this issue on a MX-6580....when making copies from the DSPF....what was the fix for this?
        Sharp put out a bulletin about one of the DSPF belts not having enough tension.
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 715
          #19
          Refer to my first post on this thread.
          • iHateSharpFusers
            • Jul 2024
            • 38
            #20
            Could you post the bulletin if you have it? I am having a hard time finding it in the bulletin library. Thanks!
            • RColon-Fraser
              • Jan 2021
              • 5
              #21
              CCE-2445
              • iHateSharpFusers
                • Jul 2024
                • 38
                #22
                CCE-2445
                Thanks!
                • Blind Avocado
                  • Jan 2021
                  • 41
                  #23
                  I have seen failing CCD units cause this type of distortion. Try replacing the lens unit
