Flaring blacks MX-3070
  • bigdaddyooo
    • Dec 2014
    • 212
    I have a 3070 kicking my ass. I have replaced the MFP-pwb, MSata, PCU pwb, Lsu pwb, TC pwb, HVT pwb, MC pwb, HDD, TCI unit, Drum unit and DV unit and Im still getting this "flaring" blacks. The 22-6 looks like it is "double struck" from a typewriter. My 46-74's the colors are good but the black is way off. I will give examples here.
    Are you the police? "No ma'am, were musicians"
  • DavePo
    • Jul 2008
    • 305
    Re: Flaring blacks MX-3070
    Looks a lot like a Laser Unit issue with the black beam.
    • bigdaddyooo
      • Dec 2014
      • 212
      I did replace the LSU and pwb so I understand what you were thinking. TY
      • kdr363
        • Apr 2019
        • 63
        Send it on vacation for a minute by changing country code (26-6). Reboot. Set it back to original country. Reboot. This will clear all sims and system settings to factory. OR, try importing clone data from another 3070.
        • OlliK1969
          • Nov 2016
          • 311
          Hi
          when you did 50-22, what is the result ?
          • copiertec
            • Jan 2016
            • 2211
            Nice tip, on the 26-6, thank you.
            • bigdaddyooo
              • Dec 2014
              • 212
              Originally posted by OlliK1969
              Hi
              It executed fine. This is bizarre. all rotate is 0.02 CMY are all under 0.4
              • copiertec
                • Jan 2016
                • 2211
                This is a strange one, being you have done everything I would have suggested. Could it be a drum or developing motor? It's just isolated to black so that would be my next guess.
                I noticed on the drive section there is also a clutch located by the black process motor.
                • bigdaddyooo
                  • Dec 2014
                  • 212
                  Ok, Ive tried both suggestions and both are a no-go. still having the problem. Im going to stop the print mid stream to check the drum and TC1 to see if the phenomenon is on either or both.
                  • bigdaddyooo
                    • Dec 2014
                    • 212
                    Re: Flaring blacks MX-3070 I FOUND IT
                    I found the problem. It seemed to me it was an LSU issue. I looked at the cable and this is what I found!!!!!image_105747139.JPG
                    • mloudy
                      • Oct 2015
                      • 790
                      Hate it when the littlest of things can kick our butts. Well done.
                      • tsbservice
                        Field tech
                        • 8020
                        I found the problem. It seemed to me it was an LSU issue. I looked at the cable and this is what I found!!!!![ATTACH=CONFIG]50262[/ATTACH]
                        You replaced LSU without examining ribbon cable both ends
                        • mojorolla
                          The Wolf
                          • 2627
                          FFC cable : "friggin flat cable" as I call them...
                          • copiertec
                            • Jan 2016
                            • 2211
                            If you can't get that flat cable back in without it bending, you can put a little bit of superglue on the backside of the bent connectors to adhere it to the cable. That has got me out of a few pinches when I would work on the old HP designjets and their trailing cables.
                            • bigdaddyooo
                              • Dec 2014
                              • 212
                              Ahhhhhh NOOOOOOOOOOOOOOOOOOOOOOOOO. I did examine it and it was right on the corner so it was very difficult to notice. so after I exhausted all of my resources, I microscoped the cable and found that. But thank you Mr. Helper. LOL
