Flaring blacks MX-3070
  • Blind Avocado
    • Jan 2021
    • 41
    #16
    Re: Flaring blacks MX-3070
    If you can't get that flat cable back in without it bending, you can put a little bit of superglue on the backside of the bent connectors to adhere it to the cable. That has got me out of a few pinches when I would work on the old HP designjets and their trailing cables.
    On some of the lower end HP desktops (LJ3035 especially) I would cut a little off the end of the cable. This saved me many times
    • tsbservice
      Field tech
      • 8060
      #17
      Originally posted by bigdaddyooo
      I have a 3070 kicking my ass. I have replaced the MFP-pwb, MSata, PCU pwb, Lsu pwb, TC pwb, HVT pwb, MC pwb, HDD, TCI unit, Drum unit and DV unit and Im still getting this "flaring" blacks. The 22-6 looks like it is "double struck" from a typewriter. My 46-74's the colors are good but the black is way off. I will give examples here.
      [ATTACH=CONFIG]50252[/ATTACH][ATTACH=CONFIG]50253[/ATTACH][ATTACH=CONFIG]50254[/ATTACH]
      Ok, Ive tried both suggestions and both are a no-go. still having the problem. Im going to stop the print mid stream to check the drum and TC1 to see if the phenomenon is on either or both.
      Ahhhhhh NOOOOOOOOOOOOOOOOOOOOOOOOO. I did examine it and it was right on the corner so it was very difficult to notice. so after I exhausted all of my resources, I microscoped the cable and found that. But thank you Mr. Helper. LOL
      Well, for sure not a helper in this case. Just observer. Good luck troubleshooting next one.
