MX6070N - Faded Black
  • Kenny
    • Jun 2009
    • 517
    Hi guys,
    got a sharp MX6070N that at first had a issue with the black developing unit.
    we have swapped out the black drum/Dv unit now which fixed the issue but now after two months its doing the same thing
    now looking at the lifes (attached) the CMY drums are end of life, i presume it could be down to them which is causing the Black DV unit to fade out?
    has about 150K
    MX6070 SAMPLE.docx MX6070 life.docx
  • ron67601
    • Apr 2024
    • 19
    Looks like your black developer is is being depleted. The diagonal lines give that away. Run T.C. 25-01 and check the black reading. If it is different then the others you need developer and possibly new drum and MK kit.
    • jp74msj55
      • Oct 2014
      • 146
      Might be the middle toner hopper unit not adding toner. Have seen this a few times. Not too terrible to replace especially if you have the RB-10 ??? on it.
      Remove that and the plastic assembly for all the drums and developers!!!!
      • Kenny
        • Jun 2009
        • 517
        as i say we did have this issue a few months a go so we replaced the black dev/drum but the issue has returned after 2 months, the units were new from sharp
        • danny464
          • May 2019
          • 81
          Sharp also recommends replacing the waste toner when the developer is being depleted but it has usually been the drum unit in our case causing the issue. Did you replace the waste toner in the 2 months since the issue came back?
          • Kenny
            • Jun 2009
            • 517
            From our system it was replaced on the 18th October, we have ordered middle hopper as well as a new DV unit/developer
            • ihatefinishers13
              Senior MFP Technician
              • Feb 2020
              • 668
              Oh boy... Where to begin... Pull the corresponding drum, if there are wear rings on it, the whole unit needs replaced (NOT just the drum/charge kit). If that looks fine, the discharge lamp could be dirty behind the process unit, the transfer contacts could need cleaned, or it also could be the MC PWB contacts or just the board itself causing it. Oh, it also could be aftermarket toner or waste boxes causing it, too. It's an expensive and fun problem to troubleshoot. SO much fun.
              • Kenny
                • Jun 2009
                • 517
                Hi guys, thankfully the above suggestions worked for that machine!
                we do have another machine the same model with the same issue but replaced DRUM UNIT, DEV UNIT, MIDDLE HOPPER, TONER FUNNEL, BOTH HV BOARDS and WASTE TONER but the faded black issue persists
                pulling my hair out
                any ideas?
                • ihatefinishers13
                  • Feb 2020
                  • 668
                  pulling my hair out
                  any ideas?
                  At this point, you have replaced mostly everything involved, minus the PCU PWB. Genuine toner?
                  • ihatefinishers13
                    • Feb 2020
                    • 668
                    pulling my hair out
                    any ideas?
                    Also, check the drum again. Sharp has had a bunch of these process units fail because of the seal under the cleaning blade. Still happens to us after replacing them sometimes.
