network printing
  • swagreis
    • Jun 2008
    • 92
    network printing
    i have a small problem that in AR M450 i can not print network i am sure from the sequence of copier installation in PC and i am sure also from IP sequence because i made it many times and it works.
    the printing order going out from PC and there is no action in machine
    i changed the PC ,network card, and the same result no print
    in the same place i changed the machine and give it the same IP that i put it in the last machine with thw same PC and it work correctly .
    an yone can advise???
  • xeroxsharp
    • Nov 2008
    • 270
    Did you try to ping the copier?
    TCP IP -enable in network set up on user interface!
    Is network card activated??????????
    did copier print as network printer before?
    when you configured printer driver,what are your port setings? protocol-LPR enable not RAW, next lp , next counting LPR enable , next SNMP enable
    • swagreis
      • Jun 2008
      • 92
      i made LPR enable not raw as usual
      but u said enable SNMP and LPR counting enable
      i am always not to enable these check boxes and working ok in all machines
      but do u mean by enable network card??
      if there a simulation for that?
      thanks for u
      • xeroxsharp
        • Nov 2008
        • 270
        thanks for u
        Try to test your network card in another copier,if it works something must be wrong with your setings-(driver or copier)
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1865
          If you're installing it where you had a cougar in place, check the port. Cougars printed through port 10001, Tigers through 9100. Using the same IP address will not work if the port is incorrect.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
