MX M365 internal finisher
  • davidmay
    • Jul 2024
    • 10
    When the first page comes out it “snags” on a black arm within the finisher which sometimes it causes a jam. I was told it needs a new stacking assembly but unavailable because of the age of machine. The arm seems to raise easily when I lift it manually.
    This gallery has 1 photos.
  • Hart
    • Feb 2024
    • 408
    Cut or sandpaper it to smooth it ?
    • boutn
      • Jun 2016
      • 547
      Check if you have touble code / jam
      F1-04
      FNM10
      FNPS_1S
      If you have one of these: Technical Report CCE-3004R
      • Toner Boy
        • Aug 2007
        • 365
        Late reply but
        you just need to remove the sticky noise damper pad the black lever rests on at idle, makes lever hard to push especially first print of the day. No parts required
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 700
          F1-04
          FNM10
          FNPS_1S
          Wrong finisher... 365 takes the MXFN17
