Developer the same?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4708
    Developer the same?
    I work mostly on Kon/Min but have a small church with a AR-M317 I've been servicing for years. Same old story, they don't have money for a new one. Anyway question is can I use the AR-450ND developer in the AR-M317 which uses the AR-271ND developer? The AR-271 is 400g and AR-450ND is 450g. If the same developer I will remove 50g to use in the M317. Thanks in advance
  • Doug.P
    • Aug 2015
    • 55
    Never tried it. They are different series machines. Let us know if it works.
    • tmw
      • Dec 2013
      • 259
      This probably shouldn't considered an official procedure. In a pinch, I have used developer meant for different machines and it has worked. The labels should have the ingredients listed. If they are the same, you could likely get away with it. I can't say what type of machines these are. If they are a similar size, it might be ok. I can't remember if it was a Sharp or Toshiba, but once I used developer for a heavy machine in a lighter duty one. It came out with grey background. So that should be taken into consideration.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4708
        Reason I asked is most Kon/Min developer is the same in later generation models.
