Email on Sharp Copiers
  • lgwilkinson
    • Nov 2016
    • 13
    Is there any way to keep the customer from using email on copiers and still be able to use RED for messages and alerts. I thought there may be a soft switch setting or something like it I can set. If not how are you using the SMTP settings for alerts and not letting the customer use your settings for themselves.
    Thanks for any help you can give.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 697
    Yeah, go to System Settings > System Control > Email Alert and Status > SMTP Settings > Uncheck "Use SMTP Server in [Network Settings]"
    • lgwilkinson
      • Nov 2016
      • 13
      Sorry I didn't specify the models I know you can do that on the mx 51 and 71 series and also the BP series but I was hoping for something on the 50 and 70 series and older. But thank you for the response.
      • boutn
        • Jun 2016
        • 547
        Maybe disable some of the settings here?
        i they cant input an address, they cant scan to email...but the alerts will work.
        • Caboose
          • Dec 2017
          • 6
          Alternatively you can just remove the scan-to-email button from the home screen. Can't scan without the button.
          • ihatefinishers13
            • Feb 2020
            • 697
            Also would need to disable the top left section, too, since you can get into it that way as well.
            • Hart
              • Feb 2024
              • 408
