BP-70C65 Bad Quality Black
  • Craigcul
    • Aug 2017
    • 70
    Hi There I wonder if anyone has had this fault the Quality of the Black is very light and it seems to be raised, you can feel the toner thick on the paper it has also pulled the Black DV I have had to replace the DV already with 5 thousand copies only.
  • Hart
    • Feb 2024
    • 366
    Check your charge roller, you need to arm them.
    Pic is a bad example, it's to disarm the charge roller before moving.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 665
      Try Hart's suggestion, but I'm hoping it's not what we had to do. We had a 70C55 do the same thing, ended up replacing the MC PWB, and it was good. Our process unit and DV units looked perfect, but BK DV was still getting pulled. It was under warranty thankfully, so after swapping the parts from another machine temporarily, we got them back. We have 2 other machines that ALL DV is being pulled, still waiting on warranty stuff to go through so we can replace the stuff on them, too. They were from the same order of 50 machines, all 3 within the same serial lot, too.
      • Craigcul
        • Aug 2017
        • 70
        Thanks yes the charge roller is armed I don't have another machine I will have to order A spare Drum unit a Dev unit and probably a MC unit as well.
        • miller01123@gmail.com
          • Jun 2019
          • 44
          There is a bulletin with a special procedure to fix light black. TT-012325_1R1. It actually works to fix this problem.
            • Jun 2019
            • 44
            I think the DV pull is related to the light copy problem. Especially if they have the light black copies and prints and then run out of toner. shortly after putting a new toner in, the DV unit empties itself. The bulletin TT-012325_1R1 solved this problem. Credit to sharp for coming up with a fix for a problem they created for a change.
            • ihatefinishers13
              • Feb 2020
              • 665
              Originally posted by miller01123@gmail.com
              I think the DV pull is related to the light copy problem especially if they have the light black copies and prints and then run out of toner. shortly after putting a new toner in, the DV unit empties itself. The bulletin TT-012325_1R1 solved this problem. Credit to sharp for coming up with a fix for a problem they created for a change.
              Strangely enough, we had both of the issues in question. We started fully recalibrating each of the 50 we had once we installed them, to make sure they were dark enough. Within that same 50 were 3 machines that were legitimately DV pull issues, as the paper was also gritty from DV on the paper. Our rep came out to check on them though, fully believing that it was just light, and he confirmed it was DV pull, not light. But I did show him 2 other machines that were light, and what we did to fix it, and approved it. Basically the same thing on the bulletin, but also doing 44-17 x2, 61-13, then 61-11 to calibrated the LSU; as well as the regular color calibration steps. It was not a fun time here for a few months, that's for sure.
              • Hart
                • Feb 2024
                • 366
                I do not have access to this bulletin (AGAIN !), can you share it please ?
                • ihatefinishers13
                  • Feb 2020
                  • 665
                  • bilyahn
                    • Dec 2006
                    • 1470
                    Hmmmm, that's (UKOG-0356FCZZ} an $80 test chart last time we purchased one [years ago]. Pretty expensive fix from the factory!!! I see precision roller has them for $160
                    We have had this happen and just reseated drums and DV units and did a 46-74 to resolve the issue.
