BP-Fuser-Ghost
  • OlliK1969
    • Nov 2016
    • 311
    BP-Fuser-Ghost
    Hi
    I have the following problem with 2 fuser units from the BP series:
    They start to smear from time to time, as if the fuser unit is not transferring the toner correctly and produces a "ghost" on the next page. See attachment.
    Have you ever had something like this with the series yourself? With a new fuser unit the error goes away immediately. Ausstellung_20250311_164147.pdf
    That in the circles, not the scan line
    Thx
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 710
    Originally posted by OlliK1969
    Hi
    Thx
    Haven't had that issue yet, but those samples make it pretty tough to tell what it's "reprinting". I would almost think there are toner specks printing, and running the fuser cleaning sheet could resolve it. That can also be setup to be done automatically.
    • Steve Tech
      • May 2024
      • 35
      There was a bulletin about increasing fuser temps for plain paper by 5 or 10 degrees to help with toner build up on separation plate, I would try that.
      • DAKOTADAN
        • Jan 2011
        • 61
        Hi
        Thx
        I have had this issue ,and it will randomly give a L4-03 error, had to replace the FB web unit, to fix for now. They start turning so hard it will break
        the gears in the fuser. These are junk. I have this same issue with some Brother DCP and MFC fusers. I have put a couple of drops of silicon oil on the ends of fuser, under the belt. These are running ok after a year of adding the oil. I am going to try this on the BP fuser that is turning hard and see if it helps.
        Dan.
        • boutn
          • Jun 2016
          • 547
          there was?
          • oscarconil
            • Oct 2021
            • 27
            Something similar happened to me with that fuser model and I had to change the fuser belt with 95,800 copies.
            • OlliK1969
              • Nov 2016
              • 311
              Update:
              Since two BP fusers failed within 24 hours, I installed the "smeared" one from a BP-70C55 into a BP-70C31, where it's currently running without issues. And I installed the heater from the device into a BP-70C65, whose fuser failed with error H3-02. What garbage
              • OlliK1969
                • Nov 2016
                • 311
                The fuser belts are supposed to last 600k, I think we would all be happy if they could last more than 50%!!
