Can't Install any drivers for Windows 11 Home .
  • timelmrep05
    • Feb 2018
    • 13
    Can't Install any drivers for Windows 11 Home . Is it to do with the Home edition as we've seen this twice this week.
    2INSTALLER HAS DETECTED AN UNSUPPORTED OPERATING SYSTEM
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 709
    Are you sure it's not because it's using an ARM based processor?
    • timelmrep05
      • Feb 2018
      • 13
      Is that the answer ?
      • ihatefinishers13
        • Feb 2020
        • 709
        Yeah, Sharp doesn't support ARM technically, you'd have to use an IPP driver. Alternatively, somehow there's a way to install the Sharp Print Support App after installing a print driver, but we haven't figured it out yet, we just bought a laptop with an ARM processor for this purpose as well. It also could be in "S" mode, but I'm not sure that exists anymore, or what error you'd receive for that.
        • mojorolla
          The Wolf
          • 2626
          Make sure the device is not in "S Mode". If so, must be turned off via the Microsoft Store. It will allow the normal driver installation and at the last moment will give an "unsupported OS" message. Some Win 11 have this on by default.
          • Hart
            • Feb 2024
            • 411
            • ihatefinishers13
              • Feb 2020
              • 709
              You transferring money from your Swiss bank account, Hart?
              • Hart
                • Feb 2024
                • 411
                Nah it's just the WeTranfer alternative that's still working.
                • sbeisner1
                  • Feb 2025
                  • 2
                  Sharp Print Support App is needed. The following link will show setup (page 4), printer installation (page 5), and then feature usage in the new print window (pages 8-18).
                  • ihatefinishers13
                    • Feb 2020
                    • 709
                    https://global.sharp/restricted/prod...psa_01a_en.pdf
                    They actually make an ARM driver now, been out since October, but they never mentioned it, and they stuck it in their software library, NOT in the print driver section.
